SUPPORT Q&A - Error when starting Client
nevets2001uk - Tuesday, June 16, 2009 5:28 AM:
I have just installed Innovator on a VPC Windows 2003 for testing. I can load it on the server but when I try from a client I get an error in the small IE window stating "Aras Innovator client has failed to initialize"
I have used the SDNS tool using the address of http://192.168.1.104/innovator which is my test server address.
The log from SDNS seems to suggest it ran properly:
   Setting security for .NET 2.0 ...
   Create new group with name "192.168.1.104/innovator" ...
Microsoft (R) .NET Framework CasPol 2.0.50727.3053
Copyright (c) Microsoft Corporation.  All rights reserved.
Added union code group with "-url" membership condition to the Machine level.
Success
 Does anyone have any thoughts as to the cause of thsi problem?
Bill - Tuesday, June 16, 2009 7:14 PM:
Do you recieve any other error from .NET or a security notification from IE?
Have you checked the IE settings against the recommended settings?
Aras Innovator 9.1 - Internet Explorer Client Machine Configuration.pdf
-Bill
nevets2001uk - Wednesday, June 17, 2009 4:40 AM:
Bill,
Thanks for the link. I hadn't seen that document. Most of the settings were correct but I did change a couple and now things seem to be working.
You've been a great help. It's much appreciated.
Steve
