Yelena - Thursday, June 18, 2009 12:56 PM:
I'de like to write a method that will delete the relationship item when relationship row is deleted.
Do anybody has an example that I can use.
Thank you,
Yelena
Andy - Thursday, June 18, 2009 2:10 PM:
Why not just make the relationship dependent?
Andy
Yelena - Friday, June 19, 2009 3:57 PM:
Andy,
Thank you for response. Could you please clarify? Maybe I did not explain correctly what i am looking for.
I have two itemtypes item1 and item2
item1 has a relationship to item2. I want the functionality which will delete the correspondent instance of item2 when relationship instance is deleted from the item1.
Thanks again for your help
Yelena
SamsAn - Saturday, June 20, 2009 12:35 PM:
Options:
1. Make IsDependent=1 for item2 ItemType (i believe this was meant by Andy).
2. Assign OnBeforeDelete and OnAfterDelete methods for item1_item2 is_relationship itemtype. OnBeforeDelete should put the relationship related_id value to session. OnAfterDelete method should take from session the related_ids to remove and remove item2 instnaces.
SamsAn.
Yelena - Wednesday, June 24, 2009 1:50 PM:
Thanks for your help,
Yelena
ksalvitelli - Friday, June 4, 2010 4:53 PM:
SamsAn,
You mention 'value to session'. How do you do that. I have set up the onBeforeDelete, now what do I do with the result? How do I pass the parameter to the OnAfterDelete Method?
Kenneth
zapping - Wednesday, June 16, 2010 6:41 AM:
Use this to set your session on the OnBeforeDelete method event. Can be a string or object like the Item itself:
CCO.Session["TheItemDeleted"] = deletedItem;
Use this to retrieve it from session on the OnAfterDelete method event
Item prevItem = (Item)CCO.Session["TheItemDeleted"]
Use this to remove it from session:
CCO.Session.Remove("TheItemDeleted");
