Murari - Friday, June 19, 2009 2:55 AM:
We are currently implementing Aras Workflow for an internal project. We require help for the following -
1) Can documents be attached in the ''Workflow Activity Completion' Sheet (either thru a standard option or customization)?
2) Can field property of a variable be set to read-only in the ''Workflow Activity Completion' Sheet (either thru a standard option or customization)?
Any help for the above would be greatly appreciated.
Regards
Murari
SamsAn - Friday, June 19, 2009 7:59 AM:
You can modify ClientscriptsInBasketInBasket-VoteDialog.html to customize the behavior. See code near 'if (milestoneType == "Process Planner")' in ClientSolutionsQPscriptsMyTasksCompletionDialog.html to see an example how to make a tab for documents visible.
SamsAn.
