Yelena - Wednesday, June 24, 2009 2:10 PM:
I need the help with the form event method that will populate the field onLoad.
I have several forms based on the itemtype's "classification" and would like to populate the field with different values when the specific form is loaded. I hope it is something very easy like:
this.setProperty("material","wood");return this;
or maybe
var itm = document.item;
var material = itm.getProperty("material");
itm.setProperty(material,'Wood');
Well, neither one is working.
I will appreciate any help.
Kind Regards,
SamsAn - Wednesday, June 24, 2009 2:49 PM:
Use OnAfterNew Client Event (see corresponding tab in ItemType form) with a method having javascript like:
this.setProperty("material", "wood");
return this;
SamsAn.
Yelena - Wednesday, June 24, 2009 3:42 PM:
Actually I wanted the value populated / changed based on the classification selected.
SamsAn - Thursday, June 25, 2009 8:26 AM:
Use OnChange classification field event, the method code should be like:
if (document.isEditMode && window.handleItemChange)
window.handleItemChange("material", "wood");
SamsAn.
Yelena - Thursday, June 25, 2009 4:40 PM:
Thanks, your example gave me a good idea what to do. Your help is greatly appreciated.
Kind Regards,
Yelena
