SUPPORT Q&A - sdns.exe installation errorl
levy - Friday, March 9, 2007 5:26 PM:
I was installing the sdns.exe and in the course of the installation I got the following message:
Application has generated an exception that could not be handled
Process id=0x1164 (4452), Thread id=0x116c (4460)
Click OK to terminate the application.
Click cancel to debug the application
And then I click cancel I get an other error message.
No debugger found.
Bill - Friday, March 9, 2007 6:45 PM:
Do you have the .NET framework installed on this client machine?
If not, here is the URL to the .NET 2.0 framework.
http://www.microsoft.com/downloads/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5&displaylang=en
Bill - Friday, March 9, 2007 7:10 PM:
Sorry, my mistake.
This error message is shown because you attempted to run the file without downloading it first.
You need to download the file (sdns.exe) to your local hard drive before running it.
levy - Thursday, April 12, 2007 11:24 AM:
Hi Bill,
Thanks for your responses.  I think that there is misunderstanding in what is going on. This error occured during the downloading of sdns.exe file, so I was not even at the running stage.  Your help is very much appreciated.
Bill - Thursday, April 12, 2007 11:43 AM:
Happy I could help.  We have updated the Troubleshooting section of the Aras Innovator - .NET Client Configuration document to help other with the same issue.  This new version of the document can be found at http://www.aras.com/support/documentation/documentation.aspx
For anyone else experiencing this problem the troubleshooting steps are as follows:
1. Open Internet Explorer
2. Type in the following web address
http://www.aras.com/support/downloads/download.aspx
3. Download the "Manual .NET Security Config Tool [sdns.exe utility]" to your
hard drive
a. Right-Click on the Download Now button next to the tool description, so
that the context menu appears.
b. Select "Save Target As..."
c. The desktop will be the easiest location to download to and find the file
later.
kate - Tuesday, July 28, 2009 11:18 PM:
When we install sdns.exe to set .NET security  , But failed..
We have checked our setup & steps..
Our IE setup Follow this document --Aras Innovator 9.0 - Internet Explorer Client Machine Configuration.pdf
Add our innovatorserver's IP to Trust Site and Security tab also follow by document.
We also see your documemt  Aras Innovator 9.0 - .NET Client Configuration.pdf
Make sure: 1.Download the “Manual .NET Security Config Tool [sdns.exe utility]” to our hard drive
                     2.administrator to execute  sdns.exe,  In the “URL” field enter the full URL path, Enter  http://172.x.x.x/Innovatorserver
when we Click "OK", it failed. Error Message as follow, Please help , Thanks!
Error messafe
If you don't need to use this dialog,use  JIT (Just In Time)  debug to see detail data.
************** Exception **************
System.ComponentModel.Win32Exception:
Access denied?
   at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo)
   at System.Diagnostics.Process.Start()
   at Aras.Tools.Sdns.Form1.setSecurity(String dnet)
   at Aras.Tools.Sdns.Form1.okBtn_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Loader Assembly **************
mscorlib
Assembly version : 1.0.5000.0
    Win32
version : 1.1.4322.2407
source code based : file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
sdns
Assembly version: 1.0.2797.25988
    Win32
source code based: file:///d:/My%20Documents/sdns.exe
   Assembly version
: 1.0.5000.0
    Win32
version: 1.1.4322.2032
source code based: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
   Assembly version
: 1.0.5000.0
    Win32
version: 1.1.4322.2407
source code based: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
Assembly version: 1.0.5000.0
    Win32
   source code based
: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
System.Windows.Forms.resources
    Win32
version: 1.1.4322.573
source code based: file:///c:/windows/assembly/gac/system.windows.forms.resources/1.0.5000.0_zh-cht_b77a5c561934e089/system.windows.forms.resources.dll
************** JIT Debug **************
If you want to use JIT (Just In Time)  Debug ,........
Bill - Wednesday, July 29, 2009 12:09 AM:
What is the OS of the client?
What versions of .NET did you install?
-Bill
kate - Wednesday, July 29, 2009 2:10 AM:
OS: Windows XP Professional SP3
IE: 6.0 SP3
At first the client had .Net framwork 1.1?2.0?3.5, but we setup sdns.exe occur error as provious post mention,
After check IE setup and install steps is follow documents , we thought  the error maybe is .Net framwork 3.5  to cause..
so we un-install all .Net framwork 1.1?2.0?3.5 , and only  install  .Net framwork 2.0 to the client , but the error is the same..
Now .NET version : 2.0
Bill - Wednesday, July 29, 2009 4:49 PM:
So, you did the following?
1) Download the sdns.exe to your local hard drive.  (Lets say the root of your C: drive, for example C:sdns.exe)
2) You open "My Computer" and browse to this folder (C:)
3) You double-click on the file to run the executable
--> Error appears.
Bill - Wednesday, July 29, 2009 7:32 PM:
One other question:
What Language is your XP running in?
-Bill
kate - Wednesday, July 29, 2009 8:39 PM:
yes,our steps just as you write..
 Error occur in step3.
XP Language: Traditional Chinese Big5.
Bill - Wednesday, July 29, 2009 11:45 PM:
Well, I don't recognize the error specifically, but let me take you down all logical paths:
1) Please confirm that you have .NET 2.0 installed on the client XP Machine
2) The error message you posted earlier says that sdns.exe is being executed from the D: drive, and .NET is installed on the C: drive.  Please move the tool to the C: drive and try executing from there.
3) Try downloading a fresh copy of the tool.
4) Try executing a repair  on .NET from Add/Remove Programs
kate - Sunday, August 2, 2009 8:30 PM:
Dear Bill,
                  Thank you for your response and suggest,
we download new sdns.exe  and new sdns.exe can setup successful~
