SUPPORT Q&A - Weird display of the initial screen without the Login/ Cancel label
Remi - Tuesday, July 7, 2009 1:16 PM:
 Below this message here the display I obtained just after the installation of Innovator. I can't see the Login and the Cancel label. I do not know if the problem is major however  I can't  log on the server. When I clik on the button that suppose to be the Login button the computer doesn't react.
I follow the installation with the documentation. During the installation when I create a new database the connection succeded.
I work with IIS 6.0, Microsoft SQL server 2005 express edition,
Best Regards,
Remi.
Remi - Thursday, July 9, 2009 9:51 AM:
Finally to sort out the display problem I modify the  login.aspx file to add a value field in both buttons
Anyway, when I am loading the page I obtained a script error for Internet Explorer with an 401 error
the remotely returned an error (401): Unauthorized
venuadepu - Friday, July 10, 2009 7:39 AM:
Hello Remi,
You should not change the login.aspx file because the problem is with your browser(may be script downloading is blocked).
I too got the same problem with my Innovator, when I am logging into innovator server in the machine where it is installed, it is loading properly, but whenever i am accessing through client machine, it is loading as you have showin.
Verify all the settings. if you solve this problem, please let me know..
Venu.
Remi - Friday, July 10, 2009 10:36 AM:
Yes,
I fixed the IE settings, plus there was an error about permission on the IIS server.
Now I can connect without any problem.
Thank you very much.
The application is awesome, I hope to install the Demo database and the multi-BOM level tree
Regards, Remi
venuadepu - Tuesday, July 14, 2009 1:03 AM:
Remi,
I am also facing same errors but unable to solve the problem. Can you please write what settings you have changed? Can you give screenshots.. That will be helpful to me...
Thanks in advance,
Venu.
