DEVELOPERS FORUM - How to get the value from the parent form to the relationship tab
Arasuser - Tuesday, July 21, 2009 10:54 PM:
 Hi ,
I need to take some value from the parent form and populate it in the relationship tab. I use the following code to get the value from the parent form and call this method on the grid event when creating a new row.
But i am getting the error "exception has been thrown by the target of an invocation" client side error.
Can anyone tell me what could be the problem?
sri
Brian - Monday, July 27, 2009 7:55 PM:
The code you are using did not post to the forum so no one will be able to help you.
If you are still stuck please post the code.
Arasuser - Monday, July 27, 2009 11:03 PM:
Hi Brian
Thanks for your query. I could able to fix it up on my own.
Thank you once again.
Srii
hiro - Thursday, August 27, 2009 11:31 PM:
Hi, I have a same stuck.
In OnChangeCell, I want to change a cell value of relationship grid row,
depending on a property value of parent form.
How to get the value from the parent form?
If possible, Let me know by a simple sample code. Please help me.
Brian - Thursday, September 3, 2009 12:53 AM:
 Hi Hiro,
You can get at the xml document (which has all of the data that is being displayed on the form) like this.
In your onChangeCell method
var itmCtx = parent.thisItem;   // This is the main xml document that belongs to the Item.
var propVal = itmCtx.getProperty("property_value_to_retrieve");  // get the Property value you want to do something with
alert(propVal);  // do something with the property value you have just retrieved.
Hope this helps.
hiro - Friday, September 4, 2009 10:32 PM:
Hi brian
I can do that, perfect sample!!
thank you.
Best regards
hiro
