DEVELOPERS FORUM - Error during Import of Product Engineering Solution
andherrm - Thursday, August 20, 2009 10:45 AM:
Normal 0 21 false false false MicrosoftInternetExplorer4
Hi all,
Unfortunately I can’t import the Product Engineering Solution (I’m using Innovator 9.1.0) with the import tool
Operating System is Windows XP (English)
************* End of reference checking ************
     ****Error message****
faultstring: The specified value for property From Date '04/29/2005' of Alias does not match the required format.
faultdetail: The specified value for property From Date '04/29/2005' of Alias does not match the required format.
faultcode:   1
faultAMLError:
<AML><Item type="User" id="462AB11C1BA942A6820A44598891B889" action="add" doGetItem="0"><default_vault keyed_name="Default" type="Vault">67BBB9204FE84A8981ED8313049BA06C</default_vault><first_name>Aras</first_name><last_name>PLM</last_name><login_name>PLM</login_name><logon_enabled>0</logon_enabled><password>68319dfbecdf1b06d3906bf5cf0b2d70</password><Relationships><Item type="Alias" id="E6432AB6945043D4904888F93C96021B" action="add"><from_date> 04/29/2005</from_date><related_id keyed_name="Aras PLM" type="Identity">56A96DA9E981481688563E2D14D5D878</related_id><sort_order>128</sort_order><source_id keyed_name="PLM" type="User">462AB11C1BA942A6820A44598891B889</source_id></Item></Relationships></Item></AML>
Updating com.aras.innovator.solution.PLM to failed release status
Set "World" value  for "Logon Allowed To" variable
end of execution : 08/20/2009 16:02:14
Sending the log file to Vault Server
Log file was sent successfully to Vault Server
Expanding the list of existing packages
I found this problematic date in the PLM.xml. When I leave the date empty I'm getting following error (a bit later)
   was obtained from cache
Item successfully applied(add)   id : 385DAF3AA91049E7BADF46EEF7545A29    keyed_name : Vendor    type : Permission
Adding item in packdefinition  id  385DAF3AA91049E7BADF46EEF7545A29 type Permission
Item already exist in packdefinition  id  385DAF3AA91049E7BADF46EEF7545A29 type Permission
Processing (add)   id : 05B4BCC7364E4C1F852ECACFFA5244D9    keyed_name : Verified PR    type : Permissio
What to do? Thanks in advance!
AndHerrm
Andy - Thursday, August 20, 2009 6:49 PM:
Why are you Importing PE?  It is included in the InnovatorSolutions database.
