SUPPORT Q&A - I can log in but "new" action pop-ups are blank
timdav - Monday, August 24, 2009 6:07 PM:
I am running a test install on my local PC at work, running Windows XP Professional x64. I have SQL Express 2005, along with the requisite .Net, IIS etc.
So far, I have managed to install Innovator, and can log in as the admin. I get the initial screen with all functionality; works fine until I select a menu item, such as "Administration, Actions.....". When I then try to select "New" (either by right-click or the top menu) I get a pop-up window that is blank.
At that point IE also becomes unresponsive, and I have to go to task manager to shut it down.
Has anyone seen this before, or is there more information I can provide?
Jennifer - Tuesday, August 25, 2009 6:07 AM:
Tim -
what version of IE are you running?  if it's 8 - that's the problem - rollback to 7 as 8 is not supported at this time.
if not 8 double check your IE settings using the guides found here www.aras.com/.../
- jen
timdav - Tuesday, August 25, 2009 5:03 PM:
Working now! Many thanks, should have guessed it was all Bill's fault....;)
