SUPPORT Q&A - Get Item By Name
mendenaresh1357 - Thursday, August 27, 2009 4:14 PM:
Hi Everyone,
                     I gave a property(of a Itemtype) datatype as 'Item'  and assigned its datasource to a Itemtype. Now i added the property to the Form. In the Form, when I use this  property and choose a particular Item from the datasource ,i get the ID of the Item. How can I get the Name of the Item assigned to the property.
Naresh
RobMcAveney - Thursday, August 27, 2009 5:31 PM:
Hi Naresh -
You need to set a Keyed Name on the datasource ItemType using the Keyed Name Order column on the Properties tab.  See "Entering ItemType Properties" in the Just Ask Innovator help.
Rob
