DEVELOPERS FORUM - User Input Parameters for Reports
mendenaresh1357 - Friday, August 28, 2009 5:24 AM:
Hi Everyone,
                         I have User Input Field ona report which takes user input. How can I enable user to input data when running the report through Aras.
Naresh
MattSchroer - Friday, August 28, 2009 10:06 AM:
Naresh,
Are you using the UserInputField Template?
This can be found in the Innovator Program Files at
..InnovatorClientscriptsReportToolTemplatesUserInputTemplate.txt
Included in the template are directions which may be able to help.
If you are already using the template, make sure the permissions on the report are set properly.
Matt
mendenaresh1357 - Friday, August 28, 2009 10:18 AM:
Hi Matt,
Am using UserInputTemplate. A dialog opens but there is no field (on dialog)to take the input value.
Naresh
rrt - Wednesday, February 10, 2016 6:15 AM:
hi Naresh are you able to find solution for your problem of user input form
if Yes then pls give me solution
Thanks in advance
