morenton - Wednesday, September 2, 2009 5:08 PM:
I wrote a VBa script which allows uploading a file from a local disk into a ARAS vault server. The script is derivated from a code published on www.motobit.com/.../ and I was helped by Yoann MAINGON (PRODEOS company) and Peter SCHROER (ARAS company). Many thanks to both of them.
You can download the script there : http://www.plmlab.fr/uploads/RIALTO/aras_upload_vba_v1.txt
It's a first step to create a connector between CATIA and a ARAS server named RIALTO which is described there : http://www.plmlab.fr/index.php?page=rialto
But you can use the VBa script for other purposes.
Your comments are welcome.
morenton - Friday, September 4, 2009 5:26 AM:
Below, you can have an overview of an example of using this VBa code :
It's a first step to create a free connector between CATIA V5 and ARAS Innovator. It does work on simple models and the connector is fully integrated to CATIA.
Pascal.
morenton - Monday, September 7, 2009 11:57 AM:
You can now download :
* the VBa code of the CATIA / ARAS connector
* the user's guide
* the UML class diagram of the data model used
And you also can see a video of the connector's main capabilities between CATIA and ARAS Innovator.
All that stuff is available there :
Regards
Pascal.
