SUPPORT Q&A - Innovator Installation Failure
dschaefer - Thursday, September 17, 2009 3:24 PM:
Followed the installation instructions but cannot seem to get the Test installation running.
I get a warning "Internet explorer has blocked this site from using an ActiveX control in an unsafe manner".
Also "Aras Innovator client has failed to initialize. Please, contact your system administrator to review your .NET security settings".
Popup blocker is disabled in IE, ActiveX control settings are as described in the installation instructions.
Help!
Sean - Thursday, September 17, 2009 5:47 PM:
dschaefer,
The set up your client machine there are several things you need to do.
The first is you must add a .NET security policy to your machine to allow Aras Innovator.  This can be done using the SDNS tool located at the Aras Downloads page (http://www.aras.com/support/downloads/)
The instructions for adding the.NET security policy can be found here (http://www.aras.com/support/documentation/9.1.0/Installation%20and%20Configuration/Aras%20Innovator%209.1%20-%20.NET%20Client%20Configuration.pdf)
Once you have added the .NET security policy you will need to add your Aras Innovator URL to the Trusted Zone of Internet Explorer and set up the Trusted Zone as outlined in the Internet Explorer Client Configuration document which you can find here (http://www.aras.com/support/documentation/9.1.0/Installation%20and%20Configuration/Aras%20Innovator%209.1%20-%20Internet%20Explorer%20Client%20Machine%20Configuration.pdf)
I hope this information helps.
Sean
dschaefer - Friday, September 18, 2009 3:03 PM:
1024x768 Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
The error I am getting is similar to what is shown in 3.2.2 of the Aras document.
The Manual .NET Security Configuration Tool “sdns.exe” appears to run fine:
   Setting security for .NET 2.0 ...
WARNING: It seems like a group with the membership URL similar to
         "localhost/.../" already exists:
   1.6.  Url - localhost/.../*: FullTrust (Exclusive LevelFinal)
NOTE: creation of multiple groups with the same name or the same
      membership URL can cause problems when running Innovator
Removing existing group shown above and create a new
group with membership URL "localhost/.../" ....
   Delete old group with membership URL "localhost/.../" ...
Microsoft (R) .NET Framework CasPol 2.0.50727.3053
Copyright (c) Microsoft Corporation.  All rights reserved.
Removed code group from the Machine level.
Success
   Create new group with name "localhost/InnovatorServer" ...
Added union code group with "-url" membership condition to the Machine level.
Success
I attempted to remove .NET 2.0 and reinstall per the information / link in 3.2.2, but I cannot uninstall “because it will affect other applications that are installed”.
I am running XP Pro and have administrator rights on the machine.
Any other ideas?
Dave
Sean - Friday, September 18, 2009 3:40 PM:
Dave,
My next guess is that the MSXML4.dll is not loading properly.  A quick fix to work around this is to make some additional changes to your Trusted Zone IE settings.  You can make these adjustments for the interim to get Aras Innovator initially loaded, but following that you may revert to the settings as outlined in the document.
ActiveX Controls and Plugins
  • Automatic Prompting for ActiveX Controls - Enabled
  • Download Unsigned ActiveX Controls - Enabled
  • Initialize and script aActiveX controls not marked as safe for scripting -Enabled
Downloads
  • Automatic Prompting for File Download - Enabled
  • File download -Enabled
After you have made these changes Aras Innovator should now load.  The usual culprit is the MSXML4.dll occasionally is not loaded properly during initial load and needs permissions opened up for this load.
Hope this does the trick for you
Sean
dschaefer - Friday, September 18, 2009 5:22 PM:
Sean,
That did it - ActiveX "not marked" and Download Auto Prompting needed to be set (others were already per the install documentation).
Dave
lmorton - Thursday, October 15, 2009 10:17 AM:
We're having this same issue on one of our client workstations. If I change the ActiveX Controls and Plugins as Sean suggests it lets me in, but I cannot revert back to settings as outlined in the document.
Any other ideas besides leaving the settings this way going forward for this one client?
Lexi
