DEVELOPERS FORUM - Parent Part should be updated automatically whenever there is a change in Child Part
sherenegladysj - Wednesday, November 11, 2009 5:58 AM:
Here is the scenario;
I have three level Part BOM (say Part_A -> Part_B -> Part_C) Part_A is top level BOM & Part_C is the bottom most BOM.
I have Released all the Part's using ECO. State of Part_A, Part_B & PArt_C is Released. Revision is "A"
I have Released again Part_C alone using ECO. Adding Goal Cost to it. Revision has become "B" and state as "REleased. Revision "A" becomes "Superseeded". This should be fine.
I'm taking Multi-level BOM Report of Part_B. It is showing the A revision of Part_C (Cost is also not showing in Cost Report) & not the latest revision of Part_C("B")
Once I add Part_B "A" revision to an ECO & it goes to Draft Changes stage. Then it's fetching the latest revision (Part_C 'B' revision) of child BOM.
When I take the Report of Part_B "A" & "B" revision Report. It is pointing to latest Revision of Part_C & Cost is also rolled up.
I want the updation to be happened automatically before Part_B undergoes an ECO.
I want to update the Parent part whenever there is a change in the Child Part. And the same can be fetched by the Report too...
Can anyone please help me to resolve this?? it is very critical for my project. We ahve 9 leveles of BOM. If the 9th BOM undergoes any change that should be reflected in 0th Level & other Levels. Otherwise entire report will be messed up...
Sherene
tstickel - Wednesday, November 11, 2009 9:55 AM:
Sherene
I believe that the answer to your problem is to modfy the Part LifeCycle Map.  For the State=Released change the Item Behavior to "Float" (assuming that it is currently set to the out-of-the-box value of "Fixed").   Be sure to read the Just Ask Innovator help on Item Behavior, it explains how the Behavior settings for the Part Bom Relationship and the Part LifeCycle Map interact.
However; you should realize that what you are asking for is contrary to standard configuration management practices.  E.g. If Part_B is in the released state and one of its BOM components, Part_C, is bumped to a new revision, then Part_B would not typically reflect that change until Part_B has gone through the ECO process.
sherenegladysj - Friday, November 13, 2009 12:47 AM:
Hi TStickel,
Thanks very much for your reply. It worked fine. Whenever there is any change in the child itemtype Parent is getting updated automatically.
But I'm facing another difficulty below is the scenario;
In the serach, If I search for "current" Part, Parent should point the latest child. If I search for "Released" Part, Parent should point to the old child.
But the revision of Parent is the Same "A". Child alone has been versionised.
Released Parent A -> Child A
Current Parent A -> Child B
I'm not sure whether the above scenario can be achieved. I tried most of the Item behavior combinations. Nothing worked out :-(
If there is any way please let me know...
Thanks again in advance,
Sherene
tstickel - Monday, November 16, 2009 11:05 AM:
In your scenario, once Child A is versioned to Child B, the relationship from Parent A to Child A is modified to point the Child B instead.  So the link between Parent A and Child A no longer exists.  Consequently, there is no way to do what you are asking for.
