malarie - Tuesday, November 17, 2009 4:24 PM:
Good day,
Is it possible to have ARAS Innovator server use an SSL port 443 instead of the normal http port?
I want to have a hosted setup, and I would like to make sure that the server is secured. I'd like to use SSL to conect to it.
public_hosted_server/innovatorserver
instead of http://.../inovatorserevr
Also, What is tyhe utility of runnin the ndns.exe tool (.netframework) Is it for security?
Thanks a lot.
Bill - Wednesday, November 18, 2009 4:20 PM:
malarie,
1) Yes, you absolutely can use HTTPS with Aras Innovator. You will just need to adjust the URL used in the VaultServerConfig.xml file found in the root of the install.
2) The sdns.exe tool sets the .NET Security Policy on the client PC. This tool is provided for situations where you are working with a test server, or when you do not have your .NET security polices managed by IT. For production deployments I recommend following the guidelines for setting up the .NET security policy, and then pushing that policy out via Active Directory deployment.
http://msdn.microsoft.com/en-us/library/aa302354.aspx
-Bill
authentic - Monday, August 15, 2011 3:59 AM:
3888Tiger4:
Moncler name came from the abbreviation in Monestier de Clermon. Our Moncler Outlet specializes in the production of outdoor sports equipment. We provide the Cheap Moncler Jackets you will just love. Our Moncler Jackets Outlet is secured and trusted by the world. Our products reach a large variety, including vests for all ages, such as the Kids Moncler Jackets which looks wonderful on the little boys and girls. Also, come and take a look, you will find the one Moncler Jackets For Women made just for you. Moncler went through a long history to reach its place today. Our Moncler Jackets Men and Moncler Shirt Women are up to date with the latest fashion trends. At the same time, Moncler Vest Men and the Moncler Vest Womens is made from the best materials and can keep you away from the harms of the bitter cold this coming winter. If you are a person extremely afraid of the cold like me, I would recommend you the Moncler Scarf which will keep your neck cosy and warm in the snow. Another one of my favorites is the Women Moncler Long Down Jacket which can give you the mysterious look as you stroll down the path in the white snow.
MonikaAgarwal - Monday, May 9, 2011 5:58 AM:
chaludan - Tuesday, November 20, 2012 10:35 AM:
Hello Bill,
I've tried to use this way but I have problem with .NET client settings. I've got message "couldn't initialize client, check your .NET configuration",the same if you forgot to use SDNS, but I've used it and set address servername/InnovatorServer.
Could you, please, help me with this settings?
Thank you!
Daniel
PatrickW - Tuesday, November 22, 2011 4:33 AM:
Hi Monika,
Did you use a self signed certificate? If yes, than that might be the problem.
-Patrick
mendenaresh1357 - Tuesday, June 12, 2012 5:23 AM:
Hi Monika,
Did you find Solution for this issue. If yes, please write the steps to achieve this.
Naresh
