walekarsa - Wednesday, November 18, 2009 7:04 AM:
Hi All,
I am trying to update a property "percent_compl". of Activity in Project managment based on the property "current_status of the Document. If it is Released then the Activity should show "percent_compl" as 100 %.
I have tried to fetch the property using the API getPropertyitem , which is of Aras.IOM.Item type. This will return an Item. How do I get the "name property of this item, which can then be used in the If then statment.
Hoping for your reply.
tstickel - Wednesday, November 18, 2009 9:57 AM:
If the getPropertyItem returned an item into "returnedItem", then the statement:
Dim returnedName As String = returnedItem.getProperty("name")
will set returnedName to the value of the "name" property of this item (assuming "returnedItem" has a property called "name")
