Arasuser - Monday, January 11, 2010 4:01 AM:
Hi All,
I was trying to do some dynamic workflow assignment. So Just used the community solution example of workflow assignment and modified it to my requirement.
Actually It works like this, A document will pass through some hirearchies and at one stage it will be allocated to a particular identity to do a task.
My problem is this dyanamic assignemt is working only if i choose the identity at the initial stage of creating the document and assign the person for this task.
If I edit this document later and assign the person at a different workflow stage then it throws the error (Get Controlled Item: "Error retriving the workflow relationship" )
Kindly advise me how should i do this?
Srii
