guyIncognito - Tuesday, January 12, 2010 11:27 AM:
I'm trying to use a C# method to generate the contents of a report, but something isn't working out.
The report worked fine when I originally developed it as a report_query xsl_stylesheet pair. I assumed loading the report_query in a C# method, applying it, and then applying the xsl_stylesheet to the result would give me the same output... but it doesn't.
I get a report back, with all the trimmings (html, head, and script tags correctly filled) but with a blank <body></body>.
I checked the result of my method by debugging in VS and the content of my result item is 100% correct with a filled <body></body>.
It seems that between the result of my method and the displaying of the report everything between the <body></body> tags is lost. Does anyone know what I'm doing wrong?
Here's my method:
String reportName = this.getProperty("report_name");
Item report = inn.getItemByKeyedName("Report", reportName);
if (report.getItemCount() < 1)
return inn.newError("Could not retrieve report " + reportName + "");
Item reportQuery = inn.newItem();
reportQuery.loadAML(report.getProperty("report_query"));
string xslStylesheet = report.getProperty("xsl_stylesheet");
Item reportQueryResult = reportQuery.apply();
string resultString = reportQueryResult.applyStylesheet(xslStylesheet, "text");
return inn.newResult(resultString);
Pravin Kumar - Wednesday, October 10, 2012 4:44 PM:
Hi There,Were you able to resolve this issue?. I have a similar problem where I am unable to view the data on the report, I get the ouput with blank data but i see the table columns defined within the style sheet. Placing the same query inside the report_query section (replaced the dynamic criteria with hardcoded parameters) with the same stylesheet on a Report item, it just works fine!.
I have a client side method that generates the dynamic query for the Report item. The pseducode for this method is as follows:
var innovator = this.getInnovator();
var XYZ = innovator.newItem();
//Construct AML and apply
var qryString="";
XYZ .loadAML(qryString);
//Get the query results
var results = XYZ .apply();
//Attach the query with the Report item that contains the stylesheet
var report = innovator.getItemByKeyedName("Report","REPORTNAME");
var style = report.getProperty("xsl_stylesheet");
var html = results .applyStylesheet(style,"text");
return html;
Appreciate any insights.
Pravin
