SOLUTION - PROGRAM MANAGEMENT - HELP - Can't import
RWright - Friday, April 13, 2007 2:26 PM:
I am unable to import the Program Management solution.
 I am using the import utility and everytime I run it, it returns an error about tags not matching.
Any ideas on how to proceed?
Thanks...Russell Wright
Bill - Friday, April 13, 2007 2:46 PM:
Hi Russel, and welcome to the forum.
Sounds like xml error to me.
If you install a database from the Innovator Solutions template, the Program Management package is already present, and does not need to be imported.
If you are trying to see something other than the standard BRS's, or just need more guidance, please post the error from the log generated by the tool.
-Bill
RWright - Friday, April 13, 2007 5:48 PM:
Bill,
 That is likely it. I installed Innovator from the framework download. I was trying to make sure that I had all the solutions installed and since it was downloadable separately, I assumed that it was not already in the solution.
THANKS....RDW
