benguela - Tuesday, April 24, 2007 9:42 AM:
I get an error when I create an ECR, attach a file and then try and save, it says Failed to upload files and then it says an internal error ahs occured.
In the event viewer I see the message pasted below, it talks about an error 404 to the url /InnovatorServer/vault/vaultserver.aspx
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 2007/04/24 03:38:57 PM
Event time (UTC): 2007/04/24 01:38:57 PM
Event ID: 778c5bbd0af94cc098ea636fd935273d
Event sequence: 25
Event occurrence: 10
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/1/Root/InnovatorServer/vault-4-128218942909218750
Trust level: Full
Application Virtual Path: /InnovatorServer/vault
Application Path: C:Program FilesArasInnovatorVaultServer
Machine name: SAI
Process information:
Process ID: 6688
Process name: aspnet_wp.exe
Account name: SAIASPNET
Exception information:
Exception type: WebException
Exception message: The remote server returned an error: (404) Not Found.
Request information:
Request URL: localhost:6060/.../vaultserver.aspx
Request path: /InnovatorServer/vault/vaultserver.aspx
User host address: 127.0.0.1
User:
Is authenticated: False
Authentication Type:
Thread account name: SAIASPNET
Thread information:
Thread ID: 6
Is impersonating: False
Stack trace: at System.Net.HttpWebRequest.GetResponse()
at Aras.Server.VaultServer.VaultServer.SendRequestToInnovatorServer(XmlDocument& inDom, String& SOAPAction, XmlDocument& outDom)
at Aras.Server.VaultServer.VaultServer.GetContType_from_server(String& fileExt)
at Aras.Server.VaultServer.VaultServer.GetContType(String& fileName)
at Aras.Server.VaultServer.VaultServer.ProcessApplyItem()
at Aras.Server.VaultServer.VaultServer.vaultserver_main1()
at Aras.Server.VaultServer.VaultServer.vaultserver_main()
at ASP.vaultserver_aspx.__Render__control1(HtmlTextWriter __w, Control parameterContainer) in C:Program FilesArasInnovatorVaultServerVaultServer.aspx:line 16
at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children)
at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer)
at System.Web.UI.Page.Render(HtmlTextWriter writer)
at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter)
at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter)
at System.Web.UI.Control.RenderControl(HtmlTextWriter writer)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Custom event details:
For more information, see Help and Support Center at go.microsoft.com/.../events.asp.
Bill - Tuesday, April 24, 2007 10:26 AM:
This type of error can have more than one cause. (DHCP settings for instance)
My first suggestion is to modify the Default Vault item:
1) From the TOC select AdministrationVaults
2) Search for and edit the Default vault
3) Replace
$[HTTP_PREFIX_SERVER]$[HTTP_HOST_SERVER]$[HTTP_PORT_SERVER]$[HTTP_PATH_SERVER]/vault/vaultserver.aspx
with
localhost:6060/.../vaultserver.aspx (I am simply pulling this URL from your error message, correct as necessary.)
4) Save, Unlock, & Close
5) Try to attach a text file to an ECR (A simple txt file is best for this test.)
If this does not work, please follow the url to the vaultserver.aspx, and post the result. (localhost:6060/.../vaultserver.aspx)
This can help me decide the next step.
Please, let me know if you have any questions.
-Bill
benguela - Tuesday, April 24, 2007 10:34 AM:
I found the problem, my IIS is running on port 6060 and I noticed that the file VaultServerConfig.xml had this
<AppServerURL>localhost/.../AppServerURL>
so I changed it to
<AppServerURL>localhost:6060/.../AppServerURL>
restarted IIS and file upload now works
suzbandit987 - Tuesday, July 17, 2007 12:08 PM:
I am basically at the same spot. I am attempting to upload a document into the innovator and I get this error.
An internal error has occured.false The remote server returned an error: (500) Internal Server Error.Client Side Error
I tried to dollow the directions in the readme file from within the vault directory, but it still isn't working. I did update my path name to the default vault, but that didn't work. Let me know, thanks.
