hardik039 - Friday, February 19, 2010 1:32 AM:
Hi all,
I am getting error page when i am clicking on "reports->ActivityTEST" named report
I have followed the steps that given in PDF Document Aras Innovator - Microsoft Reporting Services 2005 Guide.pdf
but i m steel getting following error
[WebException: The request failed with HTTP status 401: Access Denied.]
System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) +533199 System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) +204
Microsoft.ReportExecution2005.ReportExecutionService.LoadReport(String Report, String HistoryID) +65
InnovatorReportServer.Render.Page_Load(Object sender, EventArgs e) +1194
System.Web.UI.Control.OnLoad(EventArgs e) +99
System.Web.UI.Control.LoadRecursive() +47
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1061
mendenaresh1357 - Thursday, March 4, 2010 6:38 AM:
Hi har dik039,
This is permissions problem.
Can you please give me more info
about this problem
What is iis security you are implementing
like anonymous,basic,..
If you give Anonymous Acces to IIS it should work.
Naresh,
hardik039 - Thursday, March 4, 2010 7:14 AM:
Hi Naresh,
Thanks for ur reply.
That problem was solved by setting Basic security option in IIS Server
But I am not able to access Aras from remote machine the error is
System.Security.SecurityException: Request for the permission of type 'System.Security.Permissions.FileIOPermission, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' failed.
Can u solve this problem,
Hardik
