SUPPORT Q&A - Problems with Skill Management
Hugo - Tuesday, March 2, 2010 1:39 PM:
Hi, I'm Hugo San Martín, right now i'm evaluating Aras to be applied were i work
I was trying Sill Management module, but under the "Classes" item, i receive the following message:
Invalid object name 'TrainingClass_Contact'.Invalid object name 'TrainingClass_Contact'.
Also I input one "Training Course" but now I can't erase it, it displays the following:
Failed to get the ItemType with ID 579E2E64FE4A4683825B46500B05DFEF.Failed to get the ItemType with ID 579E2E64FE4A4683825B46500B05DFEF.
Can anyone help with this?
Thank you
qiuquan - Friday, October 15, 2010 5:18 AM:
Yes, seem like there is this problem. I have also encounter this issue and is trying to look for solution to resolve it.
qiuquan - Monday, October 18, 2010 2:54 AM:
Problem Solved. Think the solution is not a very complete one. There seems to be some missing ItemTypes and stuffs like "TrainingClass_Contact", Instructors and etc.  Furthermore there is one method in the solution that is pointing to this missing TrainingClass_Contact.
Solution for my cause is to simply remove the method "TrainingClass onGet" under the Server Events tab of ItemType "TrainingClass".
