SUPPORT Q&A - Aras Innovator on Server 2008 IIS7
nevets2001uk - Wednesday, March 10, 2010 4:49 PM:
We have installed Aras Innovator 9.1 SP6 on our new Windows 2008 R2 server and it seems to have installed correctly into IIS7 however when we try to connect we get the following error from the client:
Aras Innovator client has failed to initialize.
This is despite registering the domain in SDNS. Are there any specific setting changes that need to be made in IIS7 to get Aras working?
FoxyXI - Saturday, April 17, 2010 5:05 PM:
Don't know if this will help, and I'm not entirely sure I had the exact error message (I had a lot of them, all day), but I did get things working (or at least I am logged in and making users) with 2008 R2.  My problem stemmed from my IIS installation which was missing features and maybe also from 32-bit issues?.  My errors ranged from error popups during install to other messages when I tried to access Aras.  My configuration uses Server 2008 R2 and MS SQL Server Express 2008.  If it helps, here are my notes on exactly what I did today:
    22. Install Aras 9.2
      A. Install IIS - Program Files->Administrative Tools->Server Manager->Roles->Add Roles
        1. Check Web Server (IIS), Next, Next
        2. Also enable All Application Development and Security, Basic Authentication
      B. Set IIS Manager, Application Pools, Advanced Settings, Enable 32-bit applications -> TRUE
      C. Launch InnovatorSetup.msi from server
        1. Next, Accept & Next, Check all 3, Next, Default and Next, Complete and Next, Enter Key Next
        2. For Web Alias enter "aras"
        3. Set SMTP Server to "smtp.emailsrvr.com", Next
        4. Vault Name "Default", URL "localhost/.../InnovatorServer.aspx", Local Path "D:ArasVault", Next
        5. Configure Database:
          A. Database Server "SERVERSQLEXPRESS", Create a new database
          B. Server Authentication, ID: "sa" PW: [Secure Password], then click "Connect..."
          C. Database Login Options, ID: "innovator PW: [Secure Password]
          D. Database Options, Template: "Innovator Solutions", name: "InnovatorSolutions"
          E. Click Configure database, Yes
          F. Next, Install
      D. Repeat for new Application Pools: IIS Manager, Application Pools, Advanced Settings, Enable 32-bit applications -> TRUE
      E. .Net Client Config
        1. Copy sdns.exe to client computer and run
        2. http://192.168.2.231/aras, OK, then close when finished
      F. IE Setup
        1. Follow guide, use "http://192.168.2.231" as base site
      G. Client PCs cannot have Avast Script Blocker running, must remove Avast and reinstall new Client.msi
tbwork - Friday, April 15, 2011 11:40 AM:
Hi nevets2001uk,
I struggled with that as well, and have finally found the issue, at least in my set-up (Server: Win2008 R2 Standard, Client: Windows7 64bit).
When using the 32-bit version of IE8, everything works fine.
In order to start the 32-bit version instead of the default browser, I use a shortcut with the following properties:
     "C:Program Files (x86)Internet Exploreriexplore.exe" 192.168.1.100/innovatorserver
Hope this works for you and others as well.
Thomas
authentic - Monday, August 15, 2011 4:03 AM:
dgfTiger5:
The other day, as I was surfing the net, I came across those really fabulous footwear that caught my whole attention at once, the Supra Shoes UK. Yes, you are not mistaken, it is the Supra Shoes that I¡¯m talking about. The company, as a matter of fact, excels in making all kinds of shoes for all age groups and both genders. For example, the Supra Vaider UK is an excellent shoe, comes in all colours and sizes. Supra Skytop Shoes is an excellent shoe to wear when out in the wild, be it having a picnic in the park, strolling a hike in the woods, or even climbing the mountains to challenge oneself. Supra Skytop 2 makes an excellent companion no matter where you are. Another option, or I would say, another of my favourites, is the Supra TK Society that is well-knowned for their uniqueness and special designs. Having such wonderful Cheap Kids Supra for your kid would make them really happy and feel their parents love around them more than ever. Such shoes are right for all occasions and they are comfortable to wear. Supra Shoes Sale definitely is a not to miss.
Iversen - Wednesday, June 2, 2010 3:13 PM:
Remeber in Point A-2
Also install:  Security - Windows Authentication
It has to be installed before installing Aras Innovator.
Iversen - Thursday, June 3, 2010 12:31 AM:
andherrm - Thursday, June 9, 2011 2:25 AM:
Do not install Innovator under c:program files or c:program files (64Bit). Choose another directory.
Take care that in IIS there is a default web site and all other web sites are stopped during installation.
This solved my installation problems!
