savan - Monday, March 22, 2010 2:47 AM:
Hi
Friends;
Below shown is image i am getting id but i want name of the item.
I have created two itemtype called student and teacher then in student item type. then I have created relationship called Teaches Then in Teaches Itemtype (isrelationship) i have added property called teacher (data type item data source teacher) so when I am creating object(item) of student and in tab Teaches I adding property of teacher by pressing f2 but it will showing me ID instead of name of itemtype teacher
So please help me out how to get name of item in attribute insted of ID
below shown is image of it please go through it.
mendenaresh1357 - Monday, March 22, 2010 3:26 AM:
Hi Savan,
Goto Teacher Itemtype. In properties tab, there is a column called 'Keyed Name order'. Put 1 in that column against teacher property. You will get Name in place of ID.
Naresh.
savan - Monday, March 22, 2010 7:34 AM:
Hi
naresh
thanks for your reply But i am still getting ID instead of name of item in property Even i have written 1 in 'Keyed Name order' in property tab
so can you please suggest me that i have to change in data base also or in itemtype
regards
savan
mendenaresh1357 - Monday, March 22, 2010 11:52 AM:
Hi Savan,
Did you try creating a new item after Adding 'keyed name order' value. It should work..
Naresh.
savan - Tuesday, March 23, 2010 12:56 AM:
Hi
naresh
Thanks a lot i got a solution & thanks for your quick response..
Savan
