savan - Tuesday, March 30, 2010 8:53 AM:
Dear
friends
I want to know how to view log file so may i know the path where it is located or where can i see the error occured in the method.
so please give me the solution if you know as soon as possible.
Regards
Savan.
RobMcAveney - Wednesday, March 31, 2010 10:54 AM:
Please specify what information you are looking for. There is no master log file that will contain all the information you would need to track issues. There are a few different techniques depending on what problem you are having.
Since you mentioned a method, I will give you two ways to trace problems:
- In a server-side method use CCO.Utilities.WriteDebug("method_log",myValue) to log values. The log file will be in your server emp directory.
- If you have Visual Studio and are developing on the server machine, you can include the line System.Diagnostics.Debugger.Break() in your method. This will set a breakpoint and prompt you to debug the method. You can then step through your method.
Rob
