TRAINING AND EDUCATION - InnovatorPLMe910 database doesn't appears
ericlement - Wednesday, March 31, 2010 4:07 PM:
Hi
I've just install the PLMe910 demo, following the excellent guide "How To Load..."
Everything has seem running fine but when logging to Innovator, the new database doesn't apprears in the "Database" dropdown menu (Only the "InnovatorSolutions" database appears and works fine). Of course, I've check twice evry step described in the guide...
I've been using the "InnovatorPLMe910-GM-Rel-0-3-package" over an 9.1.0 SP6 CD Image and I'm running SQL Express 2008.
Can his configuration bethe source of this problem ?
Thanks for your help.
tstickel - Friday, April 2, 2010 10:39 AM:
Hi:
Assuming that you updated the InnovatorServerConfig.xml, as described in Step 8 of the "How To Load..." guide, the problem is likely solved by clearing temporary internet files in Internet Explorer.  If that doesn't work then also delete Cookies.
ericlement - Monday, April 5, 2010 10:14 AM:
Thanks Terry. It worked.
Eric.
drnorthcott - Sunday, March 13, 2011 11:26 PM:
Another reason to lose the databases in the login screen is having extra files in the InnovatorServerBin folder. I did this because I was trying to apply the 404 User Notification hotfix in 9.2.0. So I renamed UserNotifications.dll to old_UserNotifications.dll thinking I was smart but it created this problem for me.
