DEVELOPERS FORUM - Unable to save values on relationship grid written by code..
mendenaresh1357 - Monday, May 10, 2010 10:21 AM:
hi ,
I am unable to save values that I am wrting to a relationship grid on the client side.
Please see my code below.
I have written this on a onChangeCell event on the property. I am able to set the value on the client side but afer I save the item or search on the relationship grid again I lose all values that I set.
I tried to save the values that i get directly to the database. Though the values are saved to the database they get overwritten again after I save the parent item type or do a search again.
It seems that the relation grid is using values from a cache or some temporary intermediate table for which I have no handle.
I tried various tricks without success
Please help ..
here is my code
 var inno = new Innovator();
// gettin the grid
var relGrid = gridApplet;
var cellVal = gridApplet.GetCellValue(relationshipID,colNumber);
var rowcount = relGrid.GetRowCount();
var draw = relGrid.DrawGrid;
if (parseInt(rowcount) > 0)
    var colCount = relGrid.GetColumnCount();
    var selRowID = relGrid.GetSelectedID();
    var action   = relGrid.GetAction(selRowID);
    if( parseInt(colCount) > 0)
        for( var j=0; j<colCount; j++)
           var colName   = relGrid.GetColumnName(j);
           var celltoChg = "customer_cost";
           var idx     = colName.indexOf(celltoChg);
           if(parseInt(idx) >= 0)
              var cell = relGrid.Cells(selRowID,j); // get cell to manipulate
              var val  = parseInt(cellVal)/0.3;
              var i18 = inno.getI18NSessionContext();
              var ntVal = i18.ConvertToNeutral(cellVal,'float','');
              cell.setEditable(true);
              cell.SetValue(ntVal);
              //Select Item from databse to update directly
              var chgQuoteRel    = inno.newItem("analysis_quote","get");
              chgQuoteRel.setAttribute("select","id");
              chgQuoteRel.setProperty('id',selRowID);
              chgQuoteRel.apply();
              var lockstatus = chgQuoteRel.getLockStatus();
              chgQuoteRel.apply("lock");
              chgQuoteRel.setProperty('locked_by_id', top.aras.getUserID());
              chgQuoteRel.SetProperty(celltoChg,ntVal);
