APPLICATION - PRODUCT ENGINEERING - CM Email query syntax.
dbqw - Wednesday, June 2, 2010 6:35 PM:
The subject of the CM Activity Notification email has the following in the subject line.  What does [2] do?
New Innovator Activity: ${Item[@type="Activity"]/name} for ${Item[2]/item_number}
RobMcAveney - Wednesday, June 2, 2010 9:09 PM:
The [2] just means to use the second item in the response.  Based on the Query String, the second item is the controlled item of the workflow (a PR, ECR, ECN, Simple ECO or Simple MCO).  The [2] syntax is just simpler than using [@type='PR' or @type='ECR' or ...].
xueron564 - Sunday, August 14, 2011 9:04 PM:
888xuerong-4:
With the rapid development of the society of mankind, many people feel rather strained by the quick pace of things around them. As a result, searching for ways to relax oneself has become a main trend and growing fast these years. The Fingers Shoes? is one of the newest creations introduced to the world and has been welcomed by people as the shoe is very comfortable and offers a great way to relax the soles of our feet. Besides this new creation, the other shoe brands are also trying to make their new shoes fit the tastes of the crowd. The Asics Running Shoes is the shoe made by the Japanese. Such shoes are received with warm arms especially in the Asian countries because the shoes suit the tastes of the Asians better than others. Of course, the Nike Shoes Online would not be disheartened. They have also been trying to combine Asian culture with the shoes they design. Supra Shoes UK is a pair of skateboarding shoes and is especially welcomed by the young, the active and playful young generation. North Face Canada are clothes that people from all age groups can fit in when they go on an outing in the fields, or in the forests.
mn
pottsm - Sunday, February 6, 2011 11:32 AM:
Just wondering if I could get some clarrification on the syntax used in the email query
For the CM Activity Notification Query, I currently have:
<Item type="Activity" id="${Item/ActivityId}" action="get" select="name,message"/>
<Item type="${Item/@type}" id="${Item/@id}" action="get" select="item_number,title"/>
<Item type="ItemType" id="${Item/@typeId}" action="get" select="label"/>
Is this first looking for the itemtype based on the typeid of the current activity assignment, which I would assume would return "Activity Assignment", then that is used by the next query up to get the type and id (@type and @id) are the returned id and types, then that is used to get the activity information in the top item query?
or am I way off here?  If I am, what do the "@" symbols represent and how would I know that for example Item/ActivityId would be available to the query?
this all makes much more sense to me when writing methods/reports and getting the info from the xpath as a result of the AML query, but this seems cryptic because I'm not sure what initial pieces of information it has.
Thanks for any help.
SamsAn - Thursday, February 17, 2011 3:48 PM:
Hi.
Let a Workflow Process has been created for an Item (of type=Part) for example. This CM Activity Notification is used in Workflow events (for example, in OnActivityAssignment). This event has special input parameters (Item of type=Part AML node, ActivityId is an additional parameter indicating assigned activity ID). So, you can use the parameters in the query. Read Aras documentation for more details (just i did not investigate is it included into a doc).
Actually, this query is a portion of xslt stylesheet ("${..}" means "<xsl:value-of .../>") and syntax like Item/@id means id attribute of Item node according xslt syntax. So, this stylesheet is applied for input XML containing the handled Item node and those special parameter(s) and the generated query is executed on the server to fetch Activity and Item (type=Part).
<Item type="ItemType" id="${Item/@typeId}" action="get" select="label"/> is just to fetch label of Part ItemType (in the described example).
SamsAn.
pottsm - Thursday, February 17, 2011 4:05 PM:
Thank you for the reply.  I have searched the programmers guide, the report tool guide, etc and haven't been able to find the documentation that would describe extra parameters during certain activities (ex. ActivityId).  Could you point me in the right direction so I can find these additional parameters?
Is it possible to view the XML that is passed directly so all of these parameters would be visible?
Also, being that the ${..} is just an <xls:value-of>, is it possible to just use xlst in the html?  I'm looking into a scenario where I would need to iterate over a query with multiple results in an email response, so I'm hoping this might be possible.
Thanks again for any help,
Mike
SamsAn - Thursday, February 17, 2011 4:27 PM:
Hello.
Yes, it is possible to use the same syntax in html (you can review Html content of that Email Message and see the examples of use).
You can sniff input parameters in the following way (for example).
1. Create c# server-side method (name=MyMethod) saving input parameters (this.dom.OuterXml) into a file (for example) at server-side.
2. In CM Activity Notification Query, setup query like below
<Item type="Method" action="MyMethod"><params>${Item}</params></Item>
3. Start workflow, etc. to call the notification query.
-> You'll save the input xml into the file by MyMethod.
SamsAn.
Rahul. - Saturday, January 28, 2012 9:32 AM:
Hi SamsAn
I successfully started Email Notification in my Company but the message in email notification is very simple like "document is released" but i want to add some dynamic things like part no., item type, document name etc.
I know that this is possible by seeing above posts and doing lots of experiments with coding in email body but i don't get result. All i get is  email message without item no. ,item type etc.
So if you have any idea, how to get item type name, item no. etc in message or what i am missing  then plz share it.
Rahul.
