Bill - Tuesday, October 31, 2006 2:13 PM:
With the release of Internet Explorer 7, I expect people will be downloading it and using Aras Innovator with it. The following are steps to configure IE7 to allow a better and easier experience while using Aras Innovator.
1. Open an Internet Explorer window.
2. From the Menu Bar select Tools à Internet Options
a. Select the Security tab
i. Select the Trusted Sites Zone
1. Select the Sites button
2. Add the URL for Innovator to this zone.
ii. Select the Custom Level button and insure the following settings (scroll down to find an appropriate option):
1. .NET Framework-reliant components
a. Run components not signed with Authenticode - Enable
b. Run components signed with Authenticode - Enable
2. ActiveX controls and plug-ins
a. Download signed ActiveX controls - Enable or Prompt. (Prompt is a minimal permission which allows Innovator to work.)
b. Run ActiveX controls and plug-ins - Enable.
c. Script ActiveX controls marked safe for scripting - Enable.
3. Downloads
a. File download – Enable.
4. Miscellaneous
a. Allow websites to open windows without address bar or status bar - Enable
5. Scripting
a. Active scripting – Enable.
b. Select the General tab
i. In the "Browser History" section, Select the Settings button
1. Select ‘Every visit to the page’
2. Select OK
ii. In the "Tabs" section, Select the Settings button
1. In the "When a pop-up is encountered:" section select Always open Pop-ups in a new window
(Let internet explorer decides how pop-ups should open is the minimum setting allowed.)
c. Select the Advanced tab
i. Multimedia
1. Always use ClearType for HTML – Disable
a. Takes effect after you restart IE7
d. Select OK
Bill - Thursday, December 21, 2006 3:12 PM:
Look to the Aras Innovator 8.1 - Internet Explorer Client Machine Configuration for more recommended settings for using Aras Innovator 8.1 with Internet Explorer 7!
http://www.aras.com/support/documentation/documentation.aspx
