zapping - Wednesday, June 9, 2010 10:21 AM:
When a Part gets deleted i would like the corresponding entry in the Manufacturer Part also be deleted. But for purge this should not happen is there a way to differentiate between the two actions. I added a method to the onBeforeDelete event of Part and included this.
if (this.getAction().ToLower() == "delete") {
//delete from manufacturer part
Item manufPart = this.newItem("Manufacturer Part", "delete");
manufPart.setAttribute("where", "item_number = '" + part.getProperty("item_number") + "'");
manufPart = manufPart.apply();
if (manufPart.isError()) {
return manufPart;
But the this.getAction always returns 'purge'.
Any pointers pls.
Zaps.
zapping - Wednesday, June 16, 2010 6:48 AM:
Is there a means to get the instance to the version of the item that will become active when a purge is done on a versionable item.
thanks,
Zaps
zapping - Wednesday, June 16, 2010 9:50 AM:
Tried this but it returns only the latest one and itemcount also returns 1 when it should be 4.
Item versions = this.newItem("part", "get");
versions.setProperty("config_id", part.getProperty("config_id"));
versions.setAttributeProperty("generation", "condition", "lt " + (Convert.ToInt32(part.getProperty("generation"))-1));
versions.setAttribute("orderBy", "generation");
versions = versions.apply();
Tried with "where" also but strange that does not return any value
versions.setAttribute("where", "part.generation < 4 and
part.config_id = '" + part.getProperty("config_id") + "'");
Any tips please.
zaps.
