dbqw - Tuesday, June 29, 2010 5:43 PM:
I'd like to be able to add a hyperlink to an MS Outlook email to take someone directly to a document. For instance, I'd like to send an email to an engineer asking them to look at a particular section of a document, and have a link in the email so they can just click on the link and be taken to the document in Aras Innovator. There is a post on how to add a ULR (I think they meant URL) to an email, but it doesn't quite seem to work in the way I'm hoping it can.
Watter - Monday, September 5, 2011 6:34 PM:
I realize I'm digging up an old email here, but I have the same question as the fellow above an no one answered him the first time so I figured I'd throw it back out there.
I have tried a URL like
ourArasServer/.../default.aspx
but that just brings up the Aras login and ocne logged in, the normal start screen. Is there any way to jump to a specific item from a link?
Matt
fli - Tuesday, May 5, 2015 4:36 AM:
HI,
After login I get the requested Item shown...
How will the URL look for getting the latest generation?
- Christoffer
Peter Borsje - Saturday, May 9, 2015 3:08 PM:
Aras is not able to that OOTB.
You need to modify method "runStartPage" and add the 'current' feature by yourself
the url will look like: aras/.../default.aspx
if (!top.aras.setup_query.StartItem) return;
var arr = top.aras.setup_query.StartItem.split(":");
var type = arr[0];
var id = arr[1];
var current;
if( arr.length > 2){
current = arr[2];
if (!type || !id) {return;}
var itm;
if (current==="current"){
itm = top.aras.getItemLastVersion(type, id);
top.aras.setup_query.StartItem = "";
//debugger;
} else {
itm = top.aras.getItemById(type, id, 0);
//debugger;
if (itm) { top.aras.uiShowItemEx(itm, undefined, true);}
Peter
dewing - Tuesday, June 9, 2015 9:22 AM:
Are you using Secure Social? This capability could be a potential solution for your collaboration needs.
D
