SOLUTION - PROGRAM MANAGEMENT - Workflow modelling/ path with an angle
Aldihu - Sunday, July 18, 2010 12:15 PM:
Hi guys.
I´m just working at a workflow template and wonder how I can create a path with an angle?
I´ ve seen several examples (e.g. the enterprise change request from the training) where a path makes an angle of 90 degrees without passing another activity. I have only the possibillity to make a straight line. It doesn´t seem to be a big problem, but the bigger the workflow gets the more confusing it becomes.
Can anyone give me a hint?
Yoann Maingon - Sunday, July 18, 2010 4:34 PM:
right click on the path and "add break" and you should be just fine !
Yoann
Aldihu - Monday, July 19, 2010 12:28 PM:
Thanks!
