SUPPORT Q&A - Cannot access innovator from client machine XP with sp3
ravidhyd - Tuesday, July 20, 2010 2:57 AM:
Hi
I have installed aras innovator in the server(windows 2003 enterprise sp 2).
innovator is working fine with the localhost/.../
if am trying from my client machine(xp profissional, version 2002, sp 3) with http://192.168.1.8/innovatorserver
the page is displaying like this...192.168.1.8 - /InnovatorServer/Client/
it is not displaying any errors on screen..
Ravi varma
DavidSpackman - Tuesday, August 3, 2010 9:39 PM:
Ravi
Have you followed these documents?
Aras Innovator 9.2 - .NET Client Configuration.pdf
Aras Innovator 9.2 - Internet Explorer Client Machine Configuration.pdf
ravidhyd - Wednesday, August 4, 2010 12:12 AM:
Hi David
Thanks for your reply
Yes I have followed both the documents.....
even i could not connect in the same server with ip address- 192.169.1.8/.../ , where i could connect with localhost/.../
so the problem is not only from the client, the problem is connecting with the ip address from server system itself and from client.
Ravi varma
DavidSpackman - Wednesday, August 4, 2010 12:49 AM:
Ravi
What address' did you put in for SDNS.exe?
Did you include a rule for the localhost address and the named / or IP address?
You should be able to manually check the rules you have in place with CasPol.exe
I.e. on my server its
C:WINDOWSMicrosoft.NETFrameworkv2.0.50727CasPol.exe -m -ld
ravidhyd - Wednesday, August 4, 2010 2:40 AM:
Hi David
Thanks for your quick reply.
i have given this address 192.168.1.8/.../Client  for SDNS.exe
and i have checked in my server as you said but i could not understand what is there
so you pleas check image which i have attached with this reply
Ravi varma
DavidSpackman - Wednesday, August 4, 2010 2:55 AM:
Ravi
You do not need to add /Client after your address
You should only need to enter
192.168.1.8/InnovatorServer
(You can see that sdns.exe creates a batch file / caspol to create the rule, if you have a read through the batch file that it adds the slash and "Client/cbin/*)
ravidhyd - Wednesday, August 4, 2010 3:12 AM:
Hi David
Thanks for immediate response
i have tried that way also, but it is same as previous
please check the attached screen.
Ravi varma
DavidSpackman - Wednesday, August 4, 2010 10:13 PM:
Sorry Ravi
I'm not sure what is causing your issue.
Sounds like its network related / or IIS
  • Are able to see the IIS page if you go to the address? http://192.168.1.8    Can you do this via a client PC?
  • Can you ping 192.168.1.8 from the server (its own address) and from clients
  • Can you ping the internal address 127.0.0.1 on the server?
Not sure I can be much more help, sorry!
ravidhyd - Thursday, August 5, 2010 12:17 AM:
Hi David
Thanks for your support...
i too think this is IIS issue, i will try to resolve it and update you.
once again thanks for your response for my problem.
Regards
Ravi Varma
