[email protected] - Friday, August 13, 2010 5:19 AM:
Example 7.28 Code List:
// Prompt the user for the file name and retrieve the File item
var fileName = prompt("Enter the File Name:","");
var innovator = this.newInnovator();
var fileItem = innovator.getItemByKeyedName("File",fileName);
if (fileItem.isError()) {
top.aras.AlertError("File Not Found: " +fileItem.getErrorDetail());
return;
// Get the URL to the file and download it
var fileURL = top.aras.getFileURLEx(fileItem.node);
var folder = top.aras.vault.GetWorkingDir();
var results = top.aras.vault.downloadFile(fileURL);
if (!results) {
top.aras.AlertError("Unable to retrieve the file from the vault");
return;
// Open the file in Word.
try {
var word = new ActiveXObject("Word.Application");
word.visible = true;
word.documents.open(folder + "\" + fileName);
} catch(e) {
top.aras.AlertError("Unable to launch Word. File saved as: "+folder+fileName);
return;
When after I have printed these codes in a new client-method, ran this method.But there is a mistake called: The method "OpenWordFile" failed.aras_object: "-2146232828" : "Target Exception:" Client Side Error....
Yoann Maingon - Friday, August 13, 2010 5:33 AM:
Are you running Innovator 9.2 ?
can you debug it and run the program step by step to know where the issue is raised?
[email protected] - Tuesday, August 17, 2010 1:48 AM:
I have found this problem because I used a button to trigger a method.
"this" in method will be given as ui.button.
so we should replace "this" of "document.thisItem.xxxxx"
Thank you all.
[email protected] - Friday, August 13, 2010 9:50 AM:
Yes,I am running 9.2.
Having tried steps,the problem is still in this stack of codes.
var innovator = this.newInnovator();--this code sentence may be not working in Javascript Language..
