SUPPORT Q&A - SSL NotificationServer 9.2 Issues
Phil - Monday, August 16, 2010 2:28 PM:
I didn't see this posted anywhere on here, so I figured I would put it up if anyone is/has experienced a similar issue.
If you receive a SOAP-403(forbidden) error (from the NotificationServer)  after logging into Aras 9.2, SSL may be the culprit.  I had to remove SSL from the NotificationServer virutal directory in IIS ,and then the error went away.
Is there a setting somewhere that I can configure the NotificationServer to use SSL?
Sean - Tuesday, August 17, 2010 10:39 AM:
Phil,
A hotfix was developed for the open release Aras Innovator 9.2.0 to help resolve this issue.  You can download the hotfix from the Community Projects site:
http://www.aras.com/communityProjects/default.aspx?projectid=3A24A562E9104435A30787A4FD1F3564
Sean
