DEVELOPERS FORUM - "Button event code" to get data from field1 and put it in filed2. when button clicked
fli - Wednesday, August 25, 2010 5:48 AM:
when i a method for a "button onClick"
what should I write to get text from 1 box to another. ?
where can I find a definition for these window.  calls ?
thanks
Christoffer
Brian - Saturday, September 4, 2010 8:08 AM:
Hi Christoffer,
I don't know if you figured this one out yet. It was nagging at me because it should be easy.
After some effort I get the following:
IN the onClick of the button:
Assuming you have two text fields called "text0" and "text1"
var myTxt0 = document.getElementsByName("text0");
var myTxt1 = document.getElementsByName("text1");
 var myVal01 = myTxt0[0].value;
var myVal00 = myTxt1[0].value;
myTxt1[0].value = myVal01;
myTxt0[0].value = myVal00;
 return true;
This swaps the values in the fields.
I'm sure there are more "correct" ways of doing this but I couldn't figure them out.
The obvious "myTxt0.getAttribute("value") is not supported by the element returned in the document.getElementByName("text0").
Anyway. If this helps you then that's great. If not it has been a useful excercise for me.
Brian - Saturday, September 4, 2010 8:38 AM:
You can get a full collection of all of the "input" elements on the form using this:
var elements = document.getElementsByTagName("input");
var valArray = new Array();
var valArray2 = new Array();
var nameArray = new Array();
for (var j=0;j<elements.length;j++)
    var fld = elements[j];
    nameArray[j] = elements[j].name;
    valArray[j] = fld.value;
    valArray2[j] = elements[j].value;
Then once you have all the elements you can do things with them in a more "normal" fashion by looping though the array to find the input field you want and working with it.
fli - Monday, September 6, 2010 3:42 AM:
Brian
Thanks for your answer, it works perfekly for me.
do you know if there i a way to do the same in c# or is it only possible to run c# on the server-side
Christoffer
Brian - Monday, September 6, 2010 6:03 AM:
Christoffer,
C# and VB are server side programming tools only.
Javascript is the Client side programming language.
