DEVELOPERS FORUM - Add a related item for the source Item
vishal_trivedi - Sunday, October 31, 2010 5:46 AM:
I am trying to add related Item by putting filter on the source Item below is the code which shows the relationship.
<AML>
        <part_no>101</part_no>
        <Relationships>
            <Item type="Part Document" action="get">
                <related_id>
                    <Item type="Document" action="get"></Item>
                </related_id>
        </Relationships>
</AML>
In the above code it shows that there is a part with part_no :--> 101. I want to add a document on the the same part what should be the code???
- Vishal
Brian - Monday, November 1, 2010 8:49 AM:
Hi Vishal,
If the Document already exists:
<AML>
<Item type="Part Document" action="add">
<source_id><Item type="Part" where="item_number ='000-0009'"/></source_id>
<related_id><Item type="Document" where="item_number='DOC-00001'"/></related_id>
</AML>
This will create the relationship between the Part and the Document.
If the Document does not exist but the part does:
<AML>
<Item type="Part" action="edit" where="[Part].item_number ='000-0009'">
 <Relationships>
  <related_id>
   <Item type="Document" action="add">
    <item_number>DOC-000003</item_number>
  </related_id>
 </Relationships>
</AML>
this will create the Document item and the relationship from the Part to the document.
Hope this helps.
vishal_trivedi - Tuesday, November 2, 2010 8:01 AM:
Hi Brian
Thank you it works
-- Vishal
