DEVELOPERS FORUM - Info from User Item
vikramjain23 - Thursday, November 18, 2010 12:32 PM:
I am unable to get user  info like Last name, first name, login name from user item.
username = user.GetProperty("last_name")
It always return null string.
Any clues,
Vikram
Brian - Friday, November 19, 2010 10:55 PM:
Hi Vikram,
if the code you have above is a copy/paste then the syntax is wrong. user.GetProperty should be user.getProperty.
var usr = this.newItem("User", "get");
usr.setProperty("first_name", "Innovator");
usr = usr.apply();
var lName = usr.getProperty("last_name");
after this javascript code runs lName = "Admin"
Have you tested that you have a valid "user" with data in it after you do an "apply" on the server?
Hope this helps.
