Hi everyone...
I have an error with my workflow. I am using Aras 11.0 SP9.
When i create an instance of ItemType, It flow over my custom workflow.
In my workflow i defined as creator submit to the reviewer. After review process, if he reject means it will again come to creator. Creator will resubmit.
Error coming while i am resubmitting... It shows as "Conversion from type 'DBNull' to type 'String' is not valid." i can not resubmit to reviewer.
How to resolve this issue?
Sathishkumar C.
Hi Sathishkumar,
Did you create your workflow map manually, or did you try creating it by executing "Save As" on an existing workflow map?
Eli
Eli Donahue
Hi Yoann Maingon...
I created workflow like this drive.google.com/open
After creating instance of MyItemType which i have created, My workflow started. When workflow coming to this activity drive.google.com/open
I try to resubmit the document drive.google.com/open But i faced some error.
I got an error like this drive.google.com/open.
How can i resolve this?
Sathishkumar C.
Hi Yoann Maingon...
I created workflow like this. drive.google.com/open
Sathishkumar C.
Hi…
1. I have created my workflow like this drive.google.com/open
2. When create instance of myItemType, It flow over my workflow drive.google.com/open
3. At this activity I try to resubmit drive.google.com/open
4. I got an error like this “Conversion from type 'DBNull' to type 'String' is not valid.” drive.google.com/open
How can I resolve this issue?
Sathishkumar C.
