Hi everyone
Quite often we need to disable a value in a list, but previously created items with the value is still valid. Does anyone have a suggestion to a solution?
Example:
On our Part form we have a dropdown list called "Item Type". A value in the list needs to be disabled so it can't be used when creating new parts. The value is still valid for all previously created parts.
Only option in Aras is to delete the value in the list, but this leaves us with another issue. When a user opens an old part with this value, which is allowed on old parts, the dropdown field is blank even though the value is still in the database.
In our ERP system all list values have checkboxes to disable a value. If the checkbox is ticked the value is no longer selectable but items which already have this value still shows correctly.
This can't be specific for us, so I hope someone have a solution.
Thanks in advance.
Regards
Henrik Olesen
Kamstrup A/S
Denmark
Hi Yoann
Thanks for the reply. I think we will try and go for your second solution (the clean solution) :-)
Hopefully we will be able to make that work. Our target is to create a solution as generic as possible so we can reuse the code.
Kind Regards
Henrik
Hi Yoann
Kind Regards
Henrik
