Technical document PDF publication Conversion task error
Hello All,
While publishing Technical Document in PDF format I'm getting below error:
Aras.ConversionFramework.Exceptions.EventCallbackErrorException: See inner exception for details: ---> System.Exception ---> System.Web.Services.Protocols.SoapHeaderException: An error occurred creating the configuration section handler for ConverterSettings/PdfPublishingConverter: Could not load type 'Aras.Publishing.Configuration.PdfConverterConfig' from assembly 'System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' (C:\12_Aras_New\ConversionServerConfig.xml line 8)
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.EndInvoke(IAsyncResult asyncResult)
at Aras.ConversionFramework.Proxy.ConversionService.EndConvert(IAsyncResult asyncResult) in C:\Builds\CI\14740\Innovator.git\CompilableCode\_CommonFiles\ConversionService\ConversionService.cs:line 85
at Aras.Server.Core.InvokeStandardConverter.ConvertCallback(IAsyncResult ar) in C:\Builds\CI\14740\Innovator.git\CompilableCode\Core\InternalMethods\InvokeStandardConverter.cs:line 131
--- End of inner exception stack trace ---
at Aras.ConversionFramework.Models.ConversionTask.<>c__DisplayClass40_0.<OnConvertCompleted>b__1() in C:\Builds\CI\14740\Innovator.git\CompilableCode\ConversionFramework\ConversionManager\Models\ConversionTask.cs:line 281
at Aras.ConversionFramework.Models.ConversionTaskEventHandler.Execute(ConversionTask task) in C:\Builds\CI\14740\Innovator.git\CompilableCode\ConversionFramework\ConversionManager\Models\ConversionTaskEventHandler.cs:line 143
at Aras.ConversionFramework.Models.ConversionTaskEventHandler.Execute(ConversionTask task) in C:\Builds\CI\14740\Innovator.git\CompilableCode\ConversionFramework\ConversionManager\Models\ConversionTaskEventHandler.cs:line 185
at Aras.ConversionFramework.Models.ConversionTask.ExecuteEventHandlers(ConversionTaskEventType eventType) in C:\Builds\CI\14740\Innovator.git\CompilableCode\ConversionFramework\ConversionManager\Models\ConversionTask.cs:line 349
XML & HTML publication conversion is working fine.
Suhas
