Hello everyone,
did someone know when the free release will be update ?
The 12sp9 was released in august 2020, the declared plan of aras was releasing one new free version every year.
Probably they change their mind ...
Hello everyone,
Don´t underrate an angry woman ;-)
It wasn´t a showstopper bug, but I tried to find a solution for it since two years. The patch bring advantages regarding data quality but also for self-update. Manual mix/merge of Methods should be much easier to do. If you haven´t customized a lot of OOTB stuff, this one should be less relevant for you.
Do you use the latest version of the updater?
I never have seen something grayed out in the updater. But from my experience the updater don´t work in every environment cause of firewall restrictions or similar. Keep an eye on that.
Aras does geoblocking of certain countries due to spam and bots. Maybe try with VPN if possible.
Maybe the Updater checks the operation system and only suggest you "compatible" versions. I would try another computer too.
But I have no idea. Maybe someone else knows more.
Hi community,
this discussion is one year old, but I would like to keep the tradition of speculating about new open releases near the end of the year.
I am still very happy with Release 2023, but a tiny issue regarding SSL makes it hard for me to use it in production. So I right now would prefer Release 26.
What do you think, will we get a new Innovator "Release 2024"?
There will always be an open release, but the question is, will we get a new one each year or each two years. Countdown is ticking
AngelaIp "but a tiny issue regarding SSL makes it hard for me to use it in production"——What is the issue? I am planning to try the 2023 version. Thanks.
See this post for all details:
RE: SQL Server Reporting Services (SSRS) via HTTPS in Innovator Release 2023. How to fix?
If you don´t use SSRS and don´t have strict SSL requirements than it´s not a problem.
The community activity is not high, and the problems I encountered have not received a response. But ARAS is still excellent.
If your post isn´t answered, just write a small additional post to move your question to the top of the list again.
After a few days/weeks your post is not really visible anymore or people think you resolved the issue by yourself when you didn´t complain about not getting an answer. :)
Sometimes there are just not the right persons available to answer your problem or people don´t understand your problem. So just write again that you still try to solve the topic. This increase your change of getting an answer.
To stick to the original topic: I think the chance of getting a Release 2024 is very low. The lastest Innovator Release 29 is not so much different to Release 2023. The new Form editor is still a draft, so it doesn´t justify a new open release just to showcase the not yet complete editor.
Release 2023 is completely fine. But I need something to fix the SSL bug.
