How can I click TOC menu to open list directly
Hi  Community,
I want to directly open the data list after clicking on the menu. So I change TOC access to TOC View, but it will disable something function, just like refresh date list after add or update or delete.
Is there other way to achieve, except using TOC view.
By the way, how can I increase TOC content width,because I can`t see the full menu name which text too long.
  • Hi Joker,
    I am not sure if you (or me) mix things up a little. A TOC view is intended to display single (!) forms or applications. It cannot be used to replace the standard grid.
    You can directly open the data grid by clicking on the small magnifying glass. I might be possible to overwrite the default behavior when you click on some of the TOC entries to by-pass the secondary window, but I would not recommend this change.
    But at least you should be able to change the default size of the aras-naviagon-panel in the codetree. Just take a look at main.css/main.css.min.
    As you use Innovator 12, this stylesheet should do the job:
    .aras-navigation-panel {
       width: 22rem;   <-- increase this value
    Maybe adjust the stylesheet in the browser debugger first to find the best width. And document this change, cause it´s a codetree modification that will be overwritten on update.
  • Hi AngelaIp, thanks a lot for your answer. I learned how to adjust TOC width.
    For the first question, I  agree with your recommand, because the secondary window is very useful. Based on my current way(set TOC View for Itemtype), it will disable the secondary window (and related funtion, my favorite, etc).
    But we would prefer to open the data grid than the secondary window when click menu text. We are accustomed to click on text because it is easy to do. The samll magnifying glass is a bit hidden and too small to click it. We usually like to directly open the menu to browse the latest data(we have customized for this). So how can I exchange their behavior:
    chick memu context  -->  open data grid
    click the small magnifying glass  -->  open the secondary window
    Is there any other way besides this one in order to meet user needs while retaining the secondary window?
    Thanks very much.
  • Well, you could increase the size of the magnifying glass, but I understand your situation! According to what I have seen, there is a 50/50 split of what users prefer. Some mainly works with Favorites, other mainly with grid.
    What TOC modifications are possible in your Innovator depends on your Innovator version. You seem to have Innovator 12. But which version? An early one, or a late one?
    I don´t know the exact version, but in the early I12 version, TOC was mostly rendered by codetree. In later version, it´s more CUI based, which probably makes it easier to modify. From my POV I would prefer to open the grid directly if users "doubleclick" on the main TOC entry. This would provide the best of both worlds. But I never tested this variant.
    I made a quick look at the codetree. Depending on your version, you may find a cuiToc.js. I am not sure if this is the correct code part, but it looks promising.
    According to what I see in the code, it´s maybe possible to interchange the functionality. So you could try to interchange the code in the two "else ifs".
    I have not tested this and it can have negative side effects. So definitely make a backup of the original code and test in a test instance first!
    As mentioned before, this one is really not my favorite solution. I would more recommend a CUI based solution that doesn´t require a codetree modification.
    But I am happy to get the feedback if somebody wants to give it a try!
  • Hi Angela.
    Thanks for answer it make me understand codetree. I try to interchange the code in the two "else ifs", but it didn't have the expected effect. And I like your solution better! So how can I "doubleclick" to open grid ?
    Thanks very much.
  • Hi Joker,
    did anything happen at all after the change? You said that it didn´t have the expected effect. But did it have any effect?
    I have seen that my described code appears in a similar way in a couple of other codetree files. So the above was probably the wrong one.  But I am not sure which one is the correct one yet.
    I have seen references that Innovator catches the click events, so adding a doubleclick could be possible. It´s just about the correct file.
    In best case, doubleclick is supported by the TOC and the favorites pane:
    I guess even Aras would like this extension. Especially people coming from I11 often miss the direct TOC access. Doubleclick represents natural behavior of impatient humans. If you want something fast, you click more aggressively. It´s really the perfect solution!
  • Out of interest I made a quick test to add a doubleclick event to the pinned sidebar tabs and it turned out far too well!
    The modification still needs a few minor improvements and the allowed time delay is a bit too high, but in general it´s just awesome. How could be ever live without that?
    Add something like this in NavigationPanel.js:
    The solution doesn´t replace the default behavior. The secondary menu is still opened, but you instantly get the grid on the second click.
  • Oh!Angela. Thanks for your help. You are so awesome.
    I got it and made a test. The following is my test code. But when I double click, the click event is triggered at the same time. So it still needs a few minor improvements  as you said. It `s okay, I`ll fix it.
  • Offline in reply to Joker
    The effect achieved by the above code is:
    click favorite tab: open secondary window and datagrid at the same time.
    click menu text: open datagrid only
    double click menu: open secondary window and datagrid(Not expected) at the same time.(This way will cause two problem to be solved: open two datagrid tabs; open secondary window and datagrid at the same time.)
  • To open a list directly from the Table of Contents (TOC) menu, follow these simple steps:
    1. Locate TOC:
      • Find the Table of Contents (TOC) menu. It's often a list or outline of items, like chapters in a book, that helps you navigate through content.
    2. Identify List Item:
      • Look for the specific item or chapter in the TOC that you want to open. It's like finding the title of a section you want to read.
    3. Click on the Item:
      • Simply click on the name or title of the item in the TOC. It's similar to clicking on a link on a website.
    4. Direct Opening:
      • After clicking, the corresponding list or content should open directly. It's like turning to the exact page or section you selected in a book.
  • Thanks for sharing your code! I like your variant, I haven´t thought about directly calling the search grid from the select event.
    Are there any conflicts when user´s have pinned/unpinned the sidebar? Anyway, I will test your solution! It´s really a useful enhancement, thanks for bringing up the topic!
