Show property of a relationship item on the parent item's search grid
  Here is the use case I am trying to implement -
Item A is the parent item and Item B is the related item. Assume Item AB is the relationship item between the 2. On Item AB I have a few properties (let's say prop1, prop2 prop3) defined and I want these to be shown on Item A's search grid.
For a unique combination of an instance of Item A and Item B there will be a unique relationship item Item AB. The intent is to show the property values of Item AB on Item A's search grid which will be different for different instances of Item A. So if there are 100 Item A instances showing in the search grid, each one row should show a different prop1, prop2 and prop3 value.
Is there a simple way to do this?
Any help is appreciated.
Sunil
