Hi all,
I am trying to write a method to get the Item that is linked to the inbasket task of a user.
What is the recommended way to writeup method code to get the Item dynamically? Any input would be very helpful.
Thanks!
Hi gchansc,
Can you describe the context for your method? Are you retrieving the item as part of a larger method? It the method server-side or client-side? What is the use case you are trying to fulfill?
Eli
Eli Donahue
