Reports SSRS
I followed directions in the Aras Microsoft Reporting Services 2012 Guide and was to able to create a report in Visual Studio and add it to Aras Report Item. The basic report with no parameters worked fine, but when i tried to add a parameter I couldn't get it to work. Below is my report query in visual basic:
  • select item_number, name
  • from innovator.product
  • where ID=@ID
This is my Aras Report query:
  • np:id=<xsl:value-of select='@ID'/>
When I run it from the item I get a error: "False" I followed the direction from the guide, is my formatting incorrect?
Parents
  • Hi didonato, If you are still working on this issue, I recommend making sure that @id is lowercase in both the Innovator report item and in the Visual Studio query. Also if you are building the query programmatically, try using '&' to join parameters instead of '&amp;'. Eli
Reply
Children
No Data
