Hi, yes this is possible.
If you can write javascript I would suggest the following to benefit from the Aras javascript API (IOM):
you build your webpage in html which you put on the install client folder (see example in Aras11SP9\Innovator\Innovator\Client\Customer\test_page.html)
you create a new itemtype with a plurial name = "Dashboard"
Make it appear in the TOC
on TOC view in the Itemtype Config, you need to set a path to the created HTML Something like ./Customer/test_page.html
Then you should see your page when selecting from the TOC
