Hi ,
I am working on a project where I want to migrate data to Aras Innovator . In this case I want to change the created_on date of an object to original date which is present in the data . But I am not able to change this date . Is there any way I can change the date ?
Similar to date there are various attributes which cannot be modified . How to change these attributes ?
Thanks for reply !
Parents
Former Member
Hi Eli,
The system properties can be updated using SQL.
I tried following comand:
<sql>Update innovator.Part set created_on = '2016-05-16T13:08:25' where ID='item_id'</sql>
But in this case I need to know the name of the table(innovator.Part). I found that table name is same as Object name. Is it always true for all objects ? If it is not the case then how can I get the name of table for different objects at runtime?
Thanks !
-Ketan.
Hi Eli,
Thanks !
-Ketan.
