I would like to know is it possible to load a doc or docx file to aras using data loader.
I am using data loader which load the document(Item) from excel file. so is it possible to load the file(attachment) load with the parent Item (in Document File Relationship)i.e. wih Document.
Thanks.
<Item type='Document' action='add'>
<item_number>myNumber</item_number>
<name>myName</name>
<description>myDescription</description>
<Relationships>
<Item type='Document File' action='add'>
<related_id>
<Item type='File' action='add'>
<actual_filename>completePathToTheFile</actual_filename>
<filename>cadFile</filename>
<Relationships>
<Item type='Located' action='add'>
<related_id>
<Item type='vault' action='get'></Item>
</related_id>
</Item>"
</Relationships>
</related_id>
</Relationships>
I tried this AML but is gives me error as <af:legacy_faultstring><![CDATA[No items of type 'Document File' found using the criteria:
Do you mean the batch loader? If you talk about the batch loader, then it is a subscriber's feature allowing you to access Aras support. Please if it is the case get in touch with support.
