Changing ownership of a work item in a WorkFlow Task
Former Member
I'm making progress over here. Have nearly got a ticket management system configured for our company. In our case, I had to go in and carve out permissions for us from the original system structure (we are significantly simpler). To that end, I just about have everything working right with one problem.
During various stages of the lifecycle, I would like to be able to assign tasks to other users or groups. These users or groups may not normally have permission to work on a work item during that phase of its lifecycle. E.g. I have a PR ticket that is being reviewed by the normally assigned group. That group delegates the workflow task to someone outside of that group.
I would like that delegate to be able to edit the item despite the standard work flow permissions that says they cant.
Is there some way to add a permission group that says "if this task is delegated to you, you have the ability to edit its linked item, despite your permissions in the linked item"
Humm good question. I actually don't think there is something out of the box for it.
You could build a private permission which would be updated with a method on the "OnDelegate" event of the workflow activity.
